I have a Nissan Sunny FE (1.4L), year 1999. It started to show white smoke from the exhaust pipe, and I noticed that the oil level is constantly increasing. It apeared that Fuel is getting into oil. My mecanics shop said that it could be either the injectors (which I cleaned last week at the Nissan agent) or most probably the air mass meter. They are both very expensive, so I want to make sure what could be the cause of the problem before I engage into bying a set of injectors or a new air mass meter.
Your advice is appreciated. Note that I cannot drive my car now as the fuel leak into the oil compartment would cause engine damage on the long run.
Thank You
Thank You
Jan 30, 2006 at 3:39 AM
