Engine damage from catalytic converter
NISSAN
CAPTAINTOM
I have been told that my engine has been damaged because of the catalytic converter. It has been claimed that a small peice of the converter broke off and got into the engine badly damaging it. Essentially I have been told I need new engine.
Does this sound plausible?
Capt Tom
Apr 23, 2007 at 10:24 AM
That is a very remote change since the cats are so far down the exhaust port.
Apr 23, 2007 at 5:19 PM
DSCHYLLING
  • 5 POSTS
I have just been told the same thing. I do not understand.
Apr 24, 2007 at 3:38 PM
2CARPRO JACK
  • 11,533 POSTS
Not sure about the engine sucking a piece of the cat backwards into the engine,but if it was low on oil before then where did it go? If there is an oil problem, a long drive will only make it worse. What exactly did Nissan say was wrong with the engine?
Apr 24, 2007 at 5:52 PM
DSCHYLLING
  • 5 POSTS
I had the oil changed at jiffy lube just a few days prior. Nissan told me they found fuel in the oil and that the oil was extremely oil. The tech said he doesnt even think that that Jiffy Lube changed the oil. If they found fuel in the oil could this have been a problem that had been around for a while?
Apr 26, 2007 at 4:27 PM
[quote:3d00f1fadf="dschylling"]I had the oil changed at jiffy lube just a few days prior. Nissan told me they found fuel in the oil and that the oil was extremely oil. The tech said he doesnt even think that that Jiffy Lube changed the oil. If they found fuel in the oil could this have been a problem that had been around for a while?[/quote:3d00f1fadf]
What did the Nismo Tech recommended-did he changed the oil and look for dilution or whatever.
Apr 26, 2007 at 5:56 PM
BESTBET777
  • 89 POSTS
Sounds a little strange. hiighly unlikley that something could be sucked backward into the engine, cat can cause excessive backpressure but the flow is still out the exhaust, not backward into the engine. Not a good idea to get oil changed where they suck it out, they never get all the sludge in the bottom of he pan. Some shops don't even change the oil,
You might be able to suck some of the oil out and take it to a lab and get it tested and possibly tell roughly when it was changed last. It's possible it hasn't been changed in a long, long while.
Even if something got into the engine i would probably damage a valve which would mean a valve job or if somehow itt got into a cylinder it might score a cylinder, needing a new engine sounds a little much.
Apr 26, 2007 at 7:44 PM
In your description of the engine being damaged-is it: turns over and refuses to start or won't even do anything when you hit the key to start. Is the engine locked-up
I want to know what,they told you what the Cat did to the engine. give us a description is to what's happening causing it to be dead or whatever.
We need to know this before we can continue-we cannot fix your problem if we don't know what's the actual problem. Is it mechanical/fuel/ignition give us something to work with.
They told you the engine is damage because they found fuel in the crankcase-they hinting on a washed-up cylinders that won't hold compression. It might be the case-Get a compression and a leakdown test to confirm that.
About something crawling back to the engine, even if you put a Marble between the exhaust manifold and the C/Converter it will never make to the exhaust port its a one way direction deal even during the valve overlap it won't go in.
Totally clogged-up catalytic converter will prevent the engine to breath In the automotive theory they call it Volumetric Efficiency-How well the engine breaths.like us humans we inhale and exhale.
Good LUck
Apr 26, 2007 at 9:17 PM
DSCHYLLING
  • 5 POSTS
The car does start now. I believe they replaced the battery. It sounded sort of "weak" when it started and there was some sort of rattling sound coming from the engine. Any idea what this could be?
Apr 27, 2007 at 8:00 AM
PALDOZER
  • 7 POSTS
It is not possible for a piece of the cat to end up inside of the eng.as the exhaust side does not suck.However,pieces can dislodge blocking exhaust flow creating very poor performance, overheating,evencausing head gasket failure ,or even worse burning a valve .A compression test or/and a vacuum test through a reputable mechanic can help to determine where the prob. lies
Apr 27, 2007 at 11:16 AM
RULEOFNIKE
Replacing a battery will not fix a clogged converter. Replace the converter. The rattle may be due to the exhaust problem. replace the converter....power should be restored and I bet the rattle will go away.
The material inside a converter unless metal mesh is definitely not going to destroy a motor. If you take one apart you will see that it crumbles in your hand to dust. And I agree with everyone else. It is highly, highly unlikely that it would get sucked back up in the engine.
Also, look for a more reputable shop. its obvious that they don't know enough to get the job done.
Jul 26, 2016 at 8:08 AM
