I have a '95 Nissan Quest XE, 3.0 litre, 165000 miles. The coolant fan will only run when the A/C is on. I have (following a Haynes manual) checked the sending unit(ok) the relays (ok) the power to relays (ok) the fuses, both in the engine compartment and the passenger compartment (ok). I discovered this when the radiator got so hot that a tank burst, when the vehicle was idling without the A/C running. Surprisingly enough the engine still did not overheat. Do you have any ideas? Iam wondering if it could be the main (PCM) computer, but how could I diagnose that?
By the way, the fan is new - I originally thought that was the problem. Also it is a two-speed fan that is supposed to run on low once the vehicle warms up, and then on high if you pass a certain temperature. I forgot to mention, if I disconnect the temperature sensor, the fan will run on the high speed. It will only run on low when the A/C is turned on, if you turn off the A/C it stops.
Apr 9, 2007 at 1:29 PM
