P0077 P7- F / INJ TIMG FB - check engine light
2004 NISSAN
KMED
hi i did a diagnostic to the E25 diesel Nissan Caravan 2004 with the ZD30 engine. I have problems with low power when i mash the gas pedal. The engine check lights constantly blinking while driving. The van barely had power and stuttering at time the code problem is P0077 P7- F / INJ TIMG FB
HELP
Oct 22, 2010 at 7:10 AM
This code is for the intake camshaft actuator circuit is shorted or open. Start at the valve connection to see if there is any corrosion or if it is loose from engine vibration. Then clear the codes
https://www.2carpros.com/articles/check-engine-light-clear-codes
If the light comes back on with the same code I would replace the actuator.
Please let us know what you find.
Sep 19, 2017 at 4:20 PM
