2002 Other Nissan Models Vibration
2002 NISSAN
49,000 MILES • 6 CYL • 2WD • AUTOMATIC
MUTLEY7643
I have a 2002 Nissan Quest. During an oil change the dealership notified me that the cv joint boot were ripped I had them replace under warranty. I also had the struts replaced under warrenty. Still having vibration in steering wheel and also a little vibration in the gas pedal. Had tires rotated and balanced, still have problem. Had all new tires replaced with Michelin's still having the problem. The problem startes at around 70 mph. Was woundering if it might be a bad rim. I will be taking it back this week to have tire's re-balanced and rotated, will have rims looked at, at this time.
Jan 7, 2008 at 1:24 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Have the tyres rotated, and get them to inspect the tie rod ends and the steering rack is right on the sub frame, if the vibration is worse under braking, have the brake rotors inspected for run out, also ask then to make sure all is tight after the drive shaft work, especially the end lock nut as sometimes drive shafts settle in the hub a little and you can get a bit more tension on the nut after a day or two.
mark (mhpautos)
Jan 7, 2008 at 5:21 PM
