1999 Other Nissan Models
1999 NISSAN
150,000 MILES • 6 CYL • FWD • AUTOMATIC
ELMO1063
3 codes. 1 bank 1 sensor 2--sensor slow to reponse; bank 1 sensor 2--voltage high. knock sensor malfunction. had replace sensor after catalytic. clear memory. 2 days later came back with same code . got any answer
Nov 12, 2008 at 2:32 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I have been advised that the sensor after the converter is just a diagnostic sensor and the sensor before the cat is the one that will be giving the fault reading, to prove this, clear codes and unplug front sensor run engine and re check codes, are you still getting the knock sensor code as well or just the O2 fault?
Mark (mhpautos)
Nov 12, 2008 at 3:10 AM
