1993 Other Nissan Models Car wont Start randomly
1993 NISSAN
225,000 MILES • 6 CYL • 2WD • AUTOMATIC
ANGLR200
  • 7 POSTS
This is an intermittent problem that started 3 months ago with my Nissan Quest.
All of the sudden, the car would not start. Changed the battery, worked for a day, dead in the morning. Checked for a parasitic drain by connecting negative cable to battery with voltmeter and pulling fuses. No change in draw.
Car would start up quickly when jumped.
Brough the car to the mechanic. He couldnt find anything wrong and it worked and started up fine.
3 weeks later now after working great, and the car is once again dead at startup.
Other issues that could possibly be realted are:
light behind ac controls is intermittent
rear wiper works intermittently
tachometer works intermittently
back rear turn signal blink quickly like it needs a new bulb, but it doesnt. Thanks for your help.
Feb 12, 2008 at 4:12 PM
the car is once again dead at startup. Try this spray carb cleaner into the throttle body-did it fire up and died out? If so start checking the fuel system-If not its an ignition system problem.
Feb 16, 2008 at 2:44 PM
ANGLR200
  • 7 POSTS
the fuel system and ignition system seem to be working fine.
When the battery is charged, the car starts right up and runs with no problems.
Mar 3, 2008 at 5:28 PM
Lets get the battery and alternator load tested-checks out -you might have a short within the electrical system that's draining the battery.
Mar 3, 2008 at 5:47 PM
ANGLR200
  • 7 POSTS
My mechanic tested the battery (3 months old) and took off the alternater and had it tested. He said it worked fine...... Could the short in the electrical system be somewhere else?...
Mar 4, 2008 at 1:46 PM
Have your mechanic perform the battery drain test anything over .035 amp he needs to locate and correct the cause.
Mar 4, 2008 at 2:05 PM
ANGLR200
  • 7 POSTS
Ok, Ill do that.
But since the battery is currently not draining, I assume I should wait until it happens again? Then bring it in for testing?
thanks for all your help. Ill keep this updates.
Mar 5, 2008 at 3:28 PM
ANGLR200
  • 7 POSTS
Apparently, the seat control panel on the drivers side of the car (which has been loose) was pressing against the door when closed. This was causing the seat to push either all the way up or back until the battery juiced out. Thank you for all your help in figuring this out.
May 23, 2008 at 4:29 PM
