1991 Other Nissan Models truck problems
1991 NISSAN
92,000 MILES • 4 CYL • 2WD • MANUAL
SNOWKICK
I have a 1991 Nissan pickup truck, I was driving and the engine over heated stopped to check it fluid was low added antifreeze to radiator and over flow tank. Tried to drive again and overheated right away. Check engine again and noticed antifreeze in the air filter. Thought it was a cracked head gasket but not sure. what can I do to solve this do i need a new engine or not. I saw a prduct call like steel seal wondering if that works or not. Thanks
Oct 19, 2009 at 9:01 PM
Sounds like a headgasket is blown or cracked head or block-block and pressure test it to identify where its leaking
You can try your luck on the steel seal or the thermagasket seal
Oct 19, 2009 at 9:10 PM
