i have a 1990 nissan nx 1.4 auto, and it has recentley startd staying in second gear when it gets up to temprature any ideas??
Apr 26, 2008 at 5:47 AM
CERTIFIED EXPERT
When was the last fluid and filter change? could be a problem with a shifting solenoid. The computer uses the signal from the throttle position and vehicle speed sensors as throttle and governor pressures. and the coolant temperature sensor to control the overdrive-Could also be a problem within the valve body-
When all these sensors are operating properly -have the transmission pressure tested.
