truck idles good then you start to drive put in gear and then the hesitation until you push in clutch and give it gas what could this be
Apr 20, 2010 at 6:41 AM
CERTIFIED EXPERT
Has the check engine light come on? Have you checked for vacuum leaks?
Apr 22, 2010 at 8:28 AM
SBW
MEMBER
no the check engine light is not on
Apr 22, 2010 at 12:36 PM
CERTIFIED EXPERT
You may want to start checking for vacuum leaks. Also, do you know how to check for fuel pressure? If so do it. If you don't, let me know and I give you directions.
Apr 22, 2010 at 1:44 PM
SBW
MEMBER
we changed the fuel filter checked all hoses and the fuel pump then we checked the manual transmission fluid and we did not have any in there could this be the problem
Apr 23, 2010 at 6:37 AM
CERTIFIED EXPERT
If there was no fluid in it, it may have been binding.
