Hi there,
Remove wheels, split pin & large axle lock nut. tie rod end and strut lower mounting bolts (2 off) Pull hub of spline & swing free (wire up out of the way) Using a suitable lever, remove shaft from G/Box it will be a good idea to drain the transmission or use a container to catch oil . Shafts just click back in as there is an internal "C"clip that locks it home.
Mark (mhpautos)
May 29, 2008 at 2:18 AM
