1988 Nissan d21 4X4 2.4L, 96,000 miles, Oil Pump
1988 NISSAN
BET1974
  • 9 POSTS
I found an oil leak on the oil pump, so I took it off and used gasket maker. The problem is that now it won't start. Is there a certain way the gears have to go? I didn't even know it was the oil pump till I got it apart. Now I hope it is not too late.
Apr 19, 2007 at 9:02 PM
[quote:54167ac581="bet1974"]I found an oil leak on the oil pump, so I took it off and used gasket maker. The problem is that now it won't start. Is there a certain way the gears have to go? I didn't even know it was the oil pump till I got it apart. Now I hope it is not too late.[/quote:54167ac581]
If you didn't put the engine on TDC it will never start, Why- the oil pump has to align with the distributor shaft and the rotor be pointing at the no.1 cap tower-you're probably 180 degs off at the distributor shaft.
Apr 21, 2007 at 12:29 AM
BET1974
  • 9 POSTS
I did finally get a book on it. The only thing I can't do now is get the timming lined up for the new pump. Witch part of the rotor has to point at #1 plug? It has 2 points cause its daul ignition. I put the timming mark on 0 and the rotor still wants to point to # 4. I figured I was 180 out so I turned the motor one full turn back to 0 (tdc) and it still don'd go in right. Am I going to have to take the chain cover off and start from scratch?
Apr 21, 2007 at 2:20 PM
[quote:4ea4b7c0ce="bet1974"]I did finally get a book on it. The only thing I can't do now is get the timming lined up for the new pump. Witch part of the rotor has to point at #1 plug? It has 2 points cause its daul ignition. I put the timming mark on 0 and the rotor still wants to point to # 4. I figured I was 180 out so I turned the motor one full turn back to 0 (tdc) and it still don'd go in right. Am I going to have to take the chain cover off and start from scratch?[/quote:4ea4b7c0ce]
Try this put the no.1 plug wire at no.4 and follow the firing order, make sure the points are gapped properly. That don't work am afraid you have to go back in and realign everything by the book.
Apr 21, 2007 at 8:44 PM
BET1974
  • 9 POSTS
Thank you for all your help.
Apr 23, 2007 at 7:38 AM
