1983 Other Nissan Models 280zx problem
1983 NISSAN
93,000 MILES • 6 CYL • 2WD • MANUAL
JONM603
I have a problem with my 280zx. When I step on the gas it sputters real bad and seems to choke itself out. I've replaced the fuel filter many times and it runs great for a short time after changing the filter then it goes right back to the same problem. Any help you could give would be appreciated and I'd happily make a donation. thank you
Mar 15, 2008 at 4:22 PM
MASTERTECHTIM
  • 4,750 POSTS
you need to start by checking the fuel pressure. if you have less than 30 psi then you need to replace the fuel pump.
Mar 15, 2008 at 4:26 PM
