1991 Nissan Micra throttle body
1991 NISSAN MICRA
54,000 MILES • 4 CYL • 2WD • MANUAL
KINZ
after fitting a throttle body, will any tuning be required or should the part be correctly calobrated.
Feb 3, 2009 at 4:55 AM
ZACKMAN
  • 4,202 POSTS
Throttle body itself does not need adjustment, the throttle position sensor however needs to be adjusted. Signal voltage (ignition key ON, engine no running) should be between 0.45 - 0.55 volts. Rotate the TP sensor until specified voltage is achieved.
Feb 3, 2009 at 2:45 PM
