Transmission output sleeve bearing blows seal
NISSAN MAXIMA
DAVESTATION
1993 Nissan Maxima sohc v6 A/T with 120k miles and 30k since transmission rebuild by a shady mechanic (probably just swapped with a different trans)
I see a lot of problems where the transmission leaks, and I dropped mine out to see that it was gushing from the main seal. A sleeve bearing that seems to stabilize the drive shaft in the bell housing seemed to have forced the seal out, but I have no idea why -- if it was a sudden thing or over a long period of time. The sleeve should have been way down inside, but came completely out to meet the torque converter. I pushed it back in and peened it, hoping it will stay, but I don't know for how long. Any ideas why this happened and how to fix it if the seal gets pushed out again? I'm having trouble finding information about the transmission (ie. dealer repairs/recalls) or about that sleeve bearing -- is it even necessary, can it be replaced with a better one that fits snug? I'm hoping that the problem doesn't have anything to do with the oil pump because it seems to have good pressure and is drivable for now (if it was bad I would think it would blow almost immediately or not even drive) Thanks so much for taking the time to help guys, this is a really nice gesture!
Aug 28, 2007 at 7:18 PM
2CARPRO JACK
  • 11,533 POSTS
Im no trans guy, but that sounds like the bushing for the converter in the front pump.If a new one doesnt fit snugly in the pump, the pump itself may need to be repalced, the entire thing flushed at the least if the bushing walked out, then there is probably metal in the trans
Aug 29, 2007 at 8:02 AM
DAVESTATION
It doesn't actually go in the pump, it's just pressed up against it. The converter covers it, but it's not a flush fit at all. It seems like just a damper for if the shaft rocks side to side. I just wish I knew why it worked itself out in the first place. It doesn't seem like simply being loose and vibrating out would force out the seal with it... I guess it isn't very tightly pressed anymore because it's such a soft metal that it's stretched or worn with time. If that's the only problem then I guess replacing it would be the solution. I'm just hoping it's not something that's going to happen again like a faulty pump blowing it out suddenly.
Aug 29, 2007 at 11:09 PM
