the missing maxima
NISSAN MAXIMA
CHEVYMAN2
ok i have a 1990 nissan maxima 3 liter v6 it misses all the time i bought it that way. i have checked compression its good changed timing belt and tensioner checked and rechecked and ect. i also changed plugs wires cap rotor.it does have fire to all cylinders i checked for ohms resistance in the injecters and even manually powered them up all seem to be working.but the middle two cylinders are the ones that appear to be dead for some reason. whats else is there?
Apr 15, 2006 at 2:35 PM
LOSONE
  • 1,616 POSTS
It sounds like it might be an intake gasket between those two cylinders. Take a compression test and see how they read. Good luck
Apr 15, 2006 at 5:47 PM
JERVIC
If you're not using the right gas , it will make it "miss". I had a 96 that did the same thing. If it states on th gas cap to use "premium fule only" you need to use that. This may not be your problem but it was mine. Had everything cleaned up and began using premium fuel and it was fine.
Jun 12, 2006 at 9:23 PM
