Rear defroster, power door and dome light stopped working
NISSAN MAXIMA
98,000 MILES • 6 CYL • FWD • AUTOMATIC
BUGEATER33X
My 2000 Maxima's power door locks, keyless entry, rear window defroster, and interior dome lights all stopped working the same time. I checked all the fuses under the drivers side fuse panel but all the fuses are good. Is their maybe a main fuse or relay for all these items and where can I find it.
Dec 14, 2007 at 1:01 AM
2CARPRO JACK
  • 11,533 POSTS
From your other post, it looks like low system voltage is stopping them possibly the BCM seeing the low alt output
Dec 15, 2007 at 8:15 AM
CSINGER05
I have a 2001 Nissan Sentra and the exact same thing happened to me. Everything seemed to be fine but one day the horn alarm kept going off by itself. The next day my rear defrost/dome light/power door locks all quit on me. What did you do to fix the problem?
Mar 20, 2008 at 9:10 AM
TIMWOMMACK
I see this is an old question but just it happened to my 2000 maxima. No power door locks, no keyless entry, no cabin lights, and no rear window defrost. I am not clear on the response. Is there a fix?
Jan 22, 2012 at 10:28 PM
RIVERMIKERAT
  • 6,110 POSTS
I have attached images showing all of the circuit protection devices for your vehicle. Check relays, fuses, and fusible links.
Jan 25, 2012 at 6:48 AM
KERT777
Timwommack did you correct the problem on your Nissan Maxima?
I have the same problem my Nissan Maxima.
Please reply to me [email protected]
Mar 12, 2012 at 7:49 PM
RIVERMIKERAT
  • 6,110 POSTS
Have it scanned for Body Control Module fault codes. These are soft codes, as they don't affect emissions or engine performance at all. Also check the fuses and/or relays for the affected circuits.
Mar 12, 2012 at 10:50 PM
