Auto Transmission Dodgy Replacement
NISSAN MAXIMA
DEXTERX
I have a 1994 Nissan Maxima that has done 225,205 km - I recently had an autoshop install a replacement transmission not once but twice.
The first time it was done after 30 minutes driving the transmission would not go into reverse or neutral - I took it back to them and they advised they would sort it out and fit a repalcement transmission if necessary.
I picked the car up today and on the way back home, whilst stationery in a que of traffic at the lights, the auto transmission failed completely - no gears whatsoever.
I pushed the car to the side of the road and found that the transmission fluid all over the road at the point where the car lost all gears.
The garage advised the transmission plate at the bottom of the diff had been peirced by a rod or some other article whilst the car was being driven down the road - this I do not believe as the car was stationery when it lost gears and prior to this was travelling in a cue of traffic at approx 5 km or less for about 5 to 10 minutes. There was nothing on the road that could have caused any holes and the undercover housing was still in place.
They have said they can replace the plate at the bottom of the transmission/diff but can't guarantee it, the workings of the transmiission, will function.
Any ideas or suggestions i?? I think it is shoddy installation or/and a poor replacement transmission or both. Possibly the internal selection mechanism or where the transmission connnects to the dif has broken a seal or something was not in the right place when it was put back together.
Nov 29, 2007 at 12:18 AM
2CARPRO JACK
  • 11,533 POSTS
Go there and ask to see it for yourself,dont call first,just show up .If the pan has a hole in it, then I guess it is possible, but that would be a noise you would hear at that slow of a speed.Could have lost a cooler line and pumped the fluid out.There are many things that could leak on an A/T. If they refuse to stand behind their work, tow it out and have another shop look at it.
Nov 29, 2007 at 8:03 AM
