Okay, so, I stopped at a store left my car running when I came out the car was off, I had to get it towed. now my security light stays on when I try to crank my car. I had a mechanic to come look the code that popped up was U1000 then it said can communicate circuit changed the BCM and the ECM still the red light pulled off the cover under the dash and seen that the car has had an ignition replacement at some point in time. Also, a red and blue wire that have been cut and put back together, but the red light still is on, and the cooling fan is still running while trying to crank or when the car is turned to the on position.
Aug 29, 2022 at 8:57 PM
