2004 Nissan Maxima fog lights
2004 NISSAN MAXIMA
120,000 MILES • 6 CYL • FWD • MANUAL
GOODMIKE
The factory fog lights burn out after 3-6 months. The dealer replaced them the first few times for free, but wont any more. My assessment of the situation is either current or voltage is too high. If that's the case, I could put a resistoe in line to reduce current flow or parallel to reduce voltage. What do you think?
Aug 7, 2009 at 2:07 PM
MERLIN2021
  • 17,250 POSTS
I think measure the voltage at the plugs, if in normal range, try using dielectric grease in the connections, this will waterproof them...if voltage is higher than headlamp voltage, then you can try a resistor in the line...maybe a variable(potentiometer).
Aug 8, 2009 at 11:51 AM
