2003 Nissan Maxima stripped wheel bolt
2003 NISSAN MAXIMA
150,000 MILES • 6 CYL • FWD • AUTOMATIC
MANANDDONNA
I had a loose nut on a tire. It stripped out the bolt that holds the tire on. How do I replace it. Its the front tire
Apr 9, 2010 at 7:54 PM
CMDRDATATX
  • 54 POSTS
The bolts are press fitted into the hub (from behind it). They usually have a length wise grooves near the back end of the flange so it doesn't turn when you press fit the bolts. To replace it (get it from a Nissan dealer so you get an exact part.)
1. Remove wheel
2. Remove two bolts that holds the caliper and hangwith a piece of wire to the spring so it doesn't stress the hydraulic brake rubber
3. Using two large c-clamps and an small metal plate squeeze the bolt back out of the hub.
4. Press in the new bolt (use a large socket as spacer, then use one of the nut and tighten it so it pulls the bolt into the hub.
5. You're done.
Apr 13, 2010 at 5:09 PM
