2003 Nissan Maxima SHAKES EXTREMLY BAD PLEASE HELP!!!
2003 NISSAN MAXIMA
58,000 MILES • 6 CYL • 2WD • AUTOMATIC
VETCPRELUDE
  • 14 POSTS
My 2003 Nissan Maxima had a collision damage in the driver's side wheel. I had to replace all the suspension, Wheel, CV axle, rotor, and lower control arm. Then the car was ready and I toked it for a test drive, I noticed that when I hit 50MPH or more the car started vibrating extremely bad, you could not exceed that speed. If felt like if the car was jumping on the road. So I decided to take it to BIG O TIRES and do an alignment and also balanced the tires. The car keeps on doing the same thing. Could someone PLEASE HELP ME. THANK YOU
Oct 6, 2010 at 5:29 PM
CMDRDATATX
  • 54 POSTS
Your car is unsafe to drive and you need a COMPETENT repair shop to fix it. Whoever did the repair replacing those components did not do a good job, and perhaps some other components in the suspension is damaged and not yet replaced. Don't drive it for too much longer until these problems are taken care off. I doubt if anyone on this forum can give you a definitive fix. For your safety reason please get to a reputable repair/body shop and have them check ALL suspension components, and ensure that the car frame (unibody) is square. Good luck.
Oct 8, 2010 at 6:52 PM
