2001 Nissan Maxima oil burning
2001 NISSAN MAXIMA
100,000 MILES • 6 CYL • FWD • AUTOMATIC
ANTONAV
HI
I HAVE A 2001 NISSAN MAXIMA V6 2.0
ITS BURNING THE ENGINE OIL
THERE IS NO LEAKS AND I CHECKED THE SEALS AND THE RINGS.
SOMEONE TALLED ME THAT THE "PCV" COULD BE THE REASON FOR THE BURNING
THERE IS NO SMOKE
WHAT COULD BE THE REASON FOR THIS PROBLEM?
Sep 20, 2010 at 4:54 AM
If its burning oil you'll be seeing blue smoke are you? If no blue smoke its leaking somewhere-check the radiator if it has oil in it and also for external leak
Sep 20, 2010 at 5:23 AM
ANTONAV
there is no smoke and no external leak
i will check the radiator.
but what about the "pcv" valve could it be the reason?
thanks.
Sep 21, 2010 at 12:44 AM
The PCV valve purpose is to remove the crankcase vapors, you can try checking it
If its burning oil then it should be noticeable with blue smoke
Sep 21, 2010 at 8:41 AM
