2001 Nissan Maxima Map Bulb Change
2001 NISSAN MAXIMA
85,000 MILES • 6 CYL • FWD • AUTOMATIC
VSKI69
Map bulb went out, changed and and it came on for a brief moment, but now will not work at all. The dome light is not working either, as well as the interior door lights, the power locks will not work unless the key is turned on, and the homelink system seems to have no power and will not work, and lastly the remote entry will not work. Checked the fuses, and there was one that was bad, replaced it, and still none of these work. Any suggestions?
Jan 7, 2009 at 8:10 AM
YASGER
  • 83 POSTS
[quote:1445f2c6ea="vski69"]Electrical problem
2001 Nissan Maxima 6 cyl Front Wheel Drive Automatic 85000 miles
Map bulb went out, changed and and it came on for a brief moment, but now will not work at all. The dome light is not working either, as well as the interior door lights, the power locks will not work unless the key is turned on, and the homelink system seems to have no power and will not work, and lastly the remote entry will not work. Checked the fuses, and there was one that was bad, replaced it, and still none of these work. Any suggestions?[/quote:1445f2c6ea]
sounds like a blown fuse...
Jan 18, 2009 at 11:55 PM
