2000 Nissan Maxima Heater won't blow warm air
2000 NISSAN MAXIMA
11,700 MILES • 6 CYL • 2WD • AUTOMATIC
TIMOTEE123
Heater has only been blowing warm air when the engine is running over 2000 RPM. Air turns cold at idle. Now, at 2000 RPM the engine temp rises to the point of overheating while the heater does not blow warm air.
Jan 25, 2008 at 10:30 PM
BLACKOP555
  • 10,386 POSTS
Change your thermostat, check you water pump, and finally flush the system and bleed it of air. That should solve your dilema.
Jan 26, 2008 at 8:29 AM
