1999 Nissan Maxima STRUTS
1999 NISSAN MAXIMA
MISSLUCYB
Suspension problem
1999 Nissan Maxima 6 cyl Automatic
hi, last week i had work done on my car. had all 4 struts replaced. but for some reason my car does not run any better. worse if u ask me, i feel all the bumps is that normal, the man say its new& it has to adjust. is that true. also under my right tire was a ugly grinding noise& i barely made it home. i looked& the rubber on strut is coming off& cracked. is that normal?
Mar 9, 2010 at 7:53 AM
SILVERS2K
  • 7 POSTS
Did you also change the bump stops and or strut mounts? Make Tire pressures is correct also, along with an alignment
Mar 15, 2010 at 10:10 PM
