1999 Nissan Maxima DRIVING ME CRAZY
1999 NISSAN MAXIMA
NIKKI_M_400
Shakes or Wobbles problem
1999 Nissan Maxima Engine Size unknown Front Wheel Drive Automatic 150000 miles
MY CAR IS SHAKING WHEN I GO OVER 55MPH. I JUST REPLACE MY TIRES ABOUT A MONTH AGO. I JUST GOT MY BELTS CHANGED BECAUSE THEY WHERE OLD AND SQUEAKING WITH THE AC ON. AFTER THE BELT CHANGE THE CAR DROVE FINE. ABOUT 2 DAYS LATER IS WHEN IT STARTED. WHAT WOULD MAKE THE CAR SHARK AT HIGHER SPEEDS OTHER THAN THE TIRES?
Feb 28, 2008 at 12:43 PM
RACI47
  • 85 POSTS
motor mounts or rims may be out of round might i suggest after checking the mounts that you consider michelins or yokohamas as they are both very good tires if you have not put good tires on it and the rims are out the tires will not be able to stay in round also the cv axles if the boots are split may be grimy on the inside and if the balance weight has thrown off the axle this will cause it also but is extremely rare.
Apr 9, 2008 at 2:08 PM
