1999 Nissan Maxima Compressor Noise
1999 NISSAN MAXIMA
121,000 MILES • 6 CYL • FWD • AUTOMATIC
FAMOUS1
The a/c works fine. When the ac is off the compressor make a whinning almost grinding noise. When you turn it on the noise stops. It cools and works great just noisey when not on.
Sep 23, 2008 at 6:51 PM
2CARPRO JACK
  • 11,533 POSTS
Couldl be aproblem with theclutch hub bearing. Try removing the belt and spinning teh clutch hub to see if it feels rough, If so you may need a new one
Sep 24, 2008 at 7:37 AM
FAMOUS1
do you know if this can be replaced or do I need to get a whole new compressor
Sep 24, 2008 at 5:25 PM
2CARPRO JACK
  • 11,533 POSTS
Should be replaceable, but it requires special pullers to get the a/c clutch off the comp
Sep 25, 2008 at 7:44 AM
