1998 Nissan Maxima BOSE RADIO
1998 NISSAN MAXIMA
210,000 MILES • 6 CYL • FWD • AUTOMATIC
MEKA006
I have an original bose radio on the car however it won't play cd's anymore and only the driver side speaker works unless i press on the face then they all work and the display doesn't show either. how can i fix this?
Dec 31, 2009 at 7:40 PM
MAPBRD
[quote:abae13504b="meka006"]Electrical problem
1998 Nissan Maxima 6 cyl Front Wheel Drive Automatic 210000 miles
I have an original bose radio on the car however it won't play cd's anymore and only the driver side speaker works unless i press on the face then they all work and the display doesn't show either. how can i fix this?[/quote:abae13504b] I was told the the cd player was made to only play real cd's u buy not burned ones and if you've been playing those it burnd the cd reading beam out.
Jan 10, 2010 at 9:20 AM
92 MAX
  • 36 POSTS
Hi Meka
Pull the bose head unit out and take it to your local radio repair shop, call them first to see if they've repaired one like yours before so you don't pay for them to learn. If you like it get them to replace the grain of wheat bulbs inside while getting service as they don't last.
Your speaker is likley need of replacement, I've repaired the braided copper link to the cone winding before but marginal if it's worth it if new to soldering, my 92 max has a intermittent in the amplifier in drivers door so don't discount that either. confirm if amp or speaker of amp by substituting speaker after confirming appropriate impeadence or pulling unit from other door.
Don
Jan 13, 2010 at 4:45 PM
