1998 Nissan Maxima B-12 chemtool cleaner
1998 NISSAN MAXIMA
GUGANS
  • 5 POSTS
Engine Performance problem
1998 Nissan Maxima 6 cyl Automatic 130000 miles
Hi, I have purchased "Berryman B-12 Chemtool® Carburetor Fuel Injector and Fuel System Cleaner" to clean my carburetor. Is this safe for engine ?, How do I use this cleaner. Instruction says that I need to pour 1 oz for every gallon of gas, I wanted to make sure that It doesn't break anything. Please let me know how do I use this cleaner.
Sep 19, 2010 at 3:16 PM
BMRFIXIT
  • 19,053 POSTS
B12 is used when carb or injectors out of the engine
where you can sock them in it
its a very strong stuff it will take the paint of the car if became in touch with it
its not good to be used around plastic or rubber
Sep 19, 2010 at 10:07 PM
GUGANS
  • 5 POSTS
so, If I understand correctly I need to take the carb and fuel injectors out of the engine and soak with the B-12 solution. why does the instruction say that I need to put in gas tank ?
Sep 20, 2010 at 12:33 AM
BMRFIXIT
  • 19,053 POSTS
Use it as directed ,as some use it as a fuel additive ,add to fuel tank and fill it up ,
personally never used it as an additive or on a fuel injected car
Sep 20, 2010 at 5:51 AM
GUGANS
  • 5 POSTS
Does it harm the engine or other parts ?
Sep 20, 2010 at 6:37 AM
BMRFIXIT
  • 19,053 POSTS
Not that i know of
if used in moderate and as directed
Sep 20, 2010 at 10:52 PM
