1997 Nissan Maxima Engine quits when jumper cables are remo
1997 NISSAN MAXIMA
WRHOADS
Engine Performance problem
1997 Nissan Maxima 6 cyl Automatic 140,00 miles
Engine quits when jumper cables are removed after jumping off.
Jun 18, 2009 at 3:09 PM
YASGER
  • 83 POSTS
bad battery
Jun 20, 2009 at 10:23 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:b4057d7236="wrhoads"]Engine Performance problem
Engine quits when jumper cables are removed after jumping off.[/quote:b4057d7236]
If the engine will start and run with cables hooked up and then shut off once disconnected then most likely you have a charging and a battery problem. So, you should look at changing the Alternator and the Battery. If you can remove them and take them to your local parts store they can check them for you.
Jun 20, 2009 at 10:30 AM
