My 97 maxima dies in forward gears. It idles fine (no miss) when not in gear. When you put it in drive or any forward gears the rpms go up and down 2 or 3 times and then dies. If you put it in reverse you can drive it all over the place(no miss). When tou finally get it going in drive it runs fine (no miss) at cruising speeds until you stop at a light and go to start out again. Then the car stalls unless you accelerate very slowly(almost like it has a flat spot in acceleration). Sometimes it doesn't act up at all. I have changed the Knock senser, IAC valve, TPS, and ECM. I have checked for vac leaks, I've tried unplugging the transmission connections. Is there a system that is common with forward and not reverse? It acts like it's in the fuel system but not sure. Is there a procedure to follow to reprogram the ECM that I may not know about? The ECM was a used one.Would the EGR valve cause this kind of malfunction?
Jun 3, 2009 at 3:41 PM
