1996 Nissan Maxima Brake light switch
1996 NISSAN MAXIMA
KELLYR1027
1996 Nissan Maxima
i need to replace the brake light switch and i dont know how to take the old one out
Nov 10, 2010 at 2:25 PM
BLUELIGHTNIN6
  • 16,542 POSTS
REMOVAL & INSTALLATION
Unplug the electrical connector from the brake light switch.
Loosen the brake light switch locknuts.
Remove the brake light switch.
To install:
Install the switch. Turn the switch to adjust the clearance between the pedal stopper and the threaded end; the clearance should be 0.012-0.039 in. (0.3-1.0mm).
Tighten the brake light switch locknuts to 9-11 ft. lbs. (12-15 Nm).
Engage the electrical connector to the brake light switch. Make sure the brake light is off when the pedal is released.
Nov 10, 2010 at 3:10 PM
