Battery Replacement ?
1996 NISSAN MAXIMA
200,100 MILES • 6 CYL • 2WD • AUTOMATIC
SADANANDMBA76
if i fix wrong specification battery in my car what will happen?
Aug 2, 2010 at 10:42 AM
SQM
  • 6,383 POSTS
It is important to use the correct size and specification battery when finding a replacement.
https://www.2carpros.com/articles/how-a-car-battery-works
https://www.2carpros.com/articles/symptoms-of-a-bad-car-battery
If the battery does not have enough cold cranking amp then you could have starting issue. It might not start the vehicle or can have hard time starting.
If the battery dimension is incorrect you cold have fitment issue. Also if it is too tall it can hit the hood which can lead to issues.
Thank you.
Sep 3, 2021 at 12:44 PM
