1995 Nissan Maxima crankshaft pully
1995 NISSAN MAXIMA
LELACB2006
Engine Mechanical problem
1995 Nissan Maxima 6 cyl Front Wheel Drive Automatic
we need to know how to pull it off to replace a new one
Feb 18, 2010 at 7:52 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You will need to first remove the external drive belts, the bolt is a conventional R/H thread, problem is it is extremely tight, we normally use a 3/4 " impact gun, but you may be able to use 1/2 drive and remove the starter to lock the engine up with a lever on the ring gear, with the bolt removed the pulley should pull off.
mark (mhpautos)
Feb 19, 2010 at 5:45 AM
