Hi mc2133,
Thank you for the donation.
The power antenna motor or the aerial reel is causing the problem.
Extend the antenna fully by pulling on it to assist while it is going up and use wd-40 to spray onto the antenna. Use a clean piece of rag to wipe off the Wd-40 any dirt or grime that is sticking on the mast and retry. You might need a few cleaning process to get the antenna working correctly.
If cleaing does not resolve the problem, the power antenna assy has to be replaced.
Jan 11, 2010 at 8:21 AM
