[quote:858b618e59="Jeff Peacock"]Noises problem
1994 Nissan Maxima 6 cyl Four Wheel Drive Automatic 65000 miles
I repalced my fule injectors and the car runs good but there is a real loud squeeling noise maybe vacum leak. I have checked all the hoses.It seems like it might be cuming from the throttel body and intake but I am not sure. Any suggestions. I got the fuel injectors from advance auto they are not factory ones.[/quote:858b618e59]
If it is a squealing then try this.....
Look for the 2 idler pulleys.... one is on top just to the left of the A/C Compressor the other is on the bottm just under and to the right of the power steering pump....
Next have a can of spray lube wd40 or similar....
then with engine off spray the center bolt of 1 of the idler pulleys NOT both.
Start vehicle if squeal is gone replace pulley, if still there turn vehicle off and spray other idler pulley and start vehicle if squeal is gone replace pulley.
post finding here in forum
Sep 26, 2008 at 9:02 PM
