1993 Nissan Maxima timing belt
1993 NISSAN MAXIMA
222,000 MILES • 6 CYL • FWD • AUTOMATIC
AUBURNRAY
Timg belt replacement
What should i expect to pay a qualified technician? Also, I read something about a certain motor that when timing belt goes out it will ruin valves, etc
Is this my motor?
Dec 10, 2009 at 6:32 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for the donation!
Your vehicle is equipped with one of the two engines. A V6 DOHC or a V6 SOHC. Which motor is in your vehicle? The DOHC engine uses a timing chain while the SOHC uses a timing belt. Belts need replaced on a regular maintenance schedule but chains only need replaced if you are experiencing timing issues.
Dec 10, 2009 at 7:00 PM
AUBURNRAY
I would say that its a sohc. The distributor will not turn. I just wanna know what to expect to pay.And if this motor will cause problems when timing belt is lost.
Dec 10, 2009 at 7:08 PM
BLUELIGHTNIN6
  • 16,542 POSTS
estimate is below and yes your vehicle has an interference motor meaning that if timing belt fails during operation there is a great chance that the engine sustained severe internal damage..
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_1265.jpg
Dec 10, 2009 at 7:12 PM
AUBURNRAY
Whats the best way to check the engine for damage before spending the money and labor on a timing belt? I want to try to fix this myself.
Dec 10, 2009 at 8:45 PM
BLUELIGHTNIN6
  • 16,542 POSTS
taking it apart is the best way to see if the valves have been bent or not
Dec 10, 2009 at 9:34 PM
