As you instructed, I hit the gas tank with rubber mallett with the key in the ON POSITION(power to the electrical system and fuel pump). No gas came out of the open fuel line I had in engine compartment. I turned off the ignition then turned iginition on again the second time and there was gas pumping out... so it is working now.
So, does this sound like a bad fuel pump? If so the is $130.00 Delphi pump good enough or should I pay more $225 for OEM or Airtrx pump?
Nov 10, 2010 at 11:29 AM
