engine heats up?
1992 NISSAN MAXIMA
183,000 MILES • 6 CYL • 2WD • AUTOMATIC
RAYMONDLEE2
the problem is recently my engine heats up way to fast when i drive for more then 25min plus, the resevior heats the water up and begins to steam, when i check the resevior later most of the water is gone and i ahve to refill it with 50/50 anit freeze/coolent
Mar 9, 2008 at 1:52 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Pressure test system to check for external leaks, replace thermostat and check that the cooling fans are coming on, have radiator replaced. most cooling problems are in these areas, do this first.
This guide will help you fix it.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Mark (mhpautos)
Mar 11, 2008 at 4:20 AM
