1989 Nissan Maxima Emergency Brakes
1989 NISSAN MAXIMA
TOYDIE1
Brakes problem
1989 Nissan Maxima 6 cyl Front Wheel Drive Manual
Where is the emergency brake adjustment/adjuster found?
Feb 27, 2009 at 1:21 PM
MERLIN2021
  • 17,250 POSTS
Maxima Remove parking brake lever cover. Raise and support rear of vehicle. Rear wheels should lock at 9-11 notches with 44 lbs. (20 kg) force applied. Loosen lock nut and rotate adjuster until properly adjusted. © 2008 Mitchell Repair Information Co., LLC. Page 1 of 1 DISC & DRUM -1989 Nissan Maxima SE It is a nut and lock nut attached to the lever, access is from the bottom of the lever. 10mm I think!
Feb 27, 2009 at 1:28 PM
