NISSAN LIBERTY
2002 NISSAN
120,000 MILES
GIVALO
I replaced a radiator which had won out but now the gears are no enganging as per required ,First gear ,sport ,reverse are all fine ,the problem as you accerarate the gears are not changing which results in high idle and over heat .please help
May 8, 2013 at 12:36 AM
MHPAUTOS
  • 31,937 POSTS
I presume that it is an auto? so start with a transmission scan for any unresolved fault codes and ensure the trans oil level is correct and the oil is not contaminated.
May 8, 2013 at 2:21 AM
GIVALO
Thanks will give the comment and can stepper motor in the gear box contributes to the gears not change from low to hgh.
May 8, 2013 at 1:53 PM
MHPAUTOS
  • 31,937 POSTS
may be a faulty shift solenoid or a line pressure related problem, look here first.
May 9, 2013 at 2:57 AM
