I have a 2000 Nissan Frontier 2.4 L, 2WD, with 216,000 miles. I just replaced the waterpump, drove about 500 miles, engine died, rpm's went crazy. I pulled over it would still turn over, so I thought I may have no compression, my timing chain went out, or I cracked a block. Took it had the engine rebuilt (wow!) when they went to start it, it was not getting fuel. I am thinking that may have been the original problem. Is there a relay switch, how do you know if the relay switch is bad, or the fuel pump is bad. It already cost $5k for the rebuild, due to having the heater core, motor and transmission mounts, changed. I am wondering the average cost if it is determined to be the fuel pump, versus the relay. Thanks, for any help...61 year old grandma that works on the cars!!!
Jul 28, 2020 at 12:04 PM
(Merged)
