2003 Nissan Frontier Lights and signal
2003 NISSAN FRONTIER
130,000 MILES • 4 CYL • 2WD • MANUAL
THEPINEAPPLE
On my nissan frontier 2003, the stick that comes out of the steering column that controls the lights and signals is loose. right now the stick can be moved foward and backward freely without any clicking through the different modes or any physical indication of position change. The issue is that when it is pulled backward the lights go on and because it moves freely it ends up in the position just by moving it up and down through use of the signal, and I've left the lights on because of this and had my battery run down. I'd like to know if this is an easy fix that I can do myself and if so what would I need.
Aug 16, 2009 at 2:07 PM
DOCFIXIT
  • 18,828 POSTS
Probably the dimmer switch spring broke. Take covers off and see the rod coming off handle follow down to dimmer
Aug 16, 2009 at 2:32 PM
