ok, I check the sparks, it dont have any spark when cranking over. When trying to crank over the distributer router dont spend/turn at all (I took off the dis. cap to check). I also checked the distributer incase it had a broken shaft but as i turn the gear the router turns. Just took off everything to look at the timing belt but its still there and in good shape. I dont get it im very confused right now... shouldnt the timming belt be connected to the main pulley and the cam shaft sproket all should be turning.
Jun 26, 2010 at 10:45 PM
