2000 Nissan Frontier Runs rough on rainy days
2000 NISSAN FRONTIER
122,000 MILES • 4 CYL • 2WD • AUTOMATIC
JWEED
My Frontier runs rough on rainy days until about 15 minutes of running. After that all is smooth. The rough is like a real bad miss. This has not happened on a dry day and my stepdad's manual Frontier of the same year does the same thing.
Jan 13, 2009 at 5:58 PM
SERVICE WRITER
  • 9,123 POSTS
Not sure if that has a distributor or not, but spray the wires with a mist of water and see if the wires arc out. May need wires.
Do the distributor if it has it after.
Jan 13, 2009 at 6:09 PM
BUCKAROUX
  • 6 POSTS
I have a 96 pickup 4 cyl that does the same thing, I have had wires, plugs, scans, but no one can fix it, I believe its a computer glich that causes the engine to flood as soon as the humidity goes down it will run fine
Jan 17, 2009 at 2:54 PM
SERVICE WRITER
  • 9,123 POSTS
[quote:30127a0cca="buckaroux"]I have a 96 pickup 4 cyl that does the same thing, I have had wires, plugs, scans, but no one can fix it, I believe its a computer glich that causes the engine to flood as soon as the humidity goes down it will run fine[/quote:30127a0cca]
Has anyone mositure tested this when the problem is not happening?
Jan 18, 2009 at 11:03 AM
KSCORVETTE
I changed wires on my 1997 Nissan then sprayed with WD-40. No more problems.
Apr 9, 2011 at 1:22 AM
