1st 3 Blower speeds not working (HVAC)
NISSAN FRONTIER
KURTTIME
1999 Nissan Frontier XE 4WD extended cab Pickup
98,700 miles
Only the highest speed of my cab heater (blower) is functional. The lower 3 speeds do not work. Is this probably a bad capacitor or a relay of some kind? How do I locate the relay, capacitor, or switch for replacement? How should I attack this problem?
Thank you!
Kurt Turrell
Mar 2, 2006 at 10:25 PM
FISHERMAN
  • 937 POSTS
first check the switch.. some times i found that the plastic melts in to the contacts, because of the load heat ......
start checking that.
Mar 3, 2006 at 9:44 AM
KNIGHTRIDERKITT2000
  • 93 POSTS
try replacing your blower motor resistor, I have a subaru that had the same problem, bought one from a junk yard for $2.50 because they are around 50.00 for my car. that solved the problem.
check behind glovebox in heater housing if not there go to www.autozone.com they have a link to tell you where it is.
Apr 3, 2006 at 12:55 PM
