1976 Datsun 120Y White smoke from exhaust.
1976 DATSUN 120Y
MATT3357
Engine Cooling problem
1976 Datsun 120Y 4 cyl Two Wheel Drive Manual - miles
Hi. on start *cold* appears to be coolant dripping from exhaust (could just be moister) car does not appear to be loosing coolant or over heating. After running for a few minutes this heavy white smoke disappears.
Could it be a minor head gasket crack?
Jun 11, 2009 at 3:07 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
The moisture dripping when cold is normal, but the white smoke is a bit of a worry, i would get a head check done just to be sure, this will test for Co2 in the cooling system, as sure sign that you have a head problem.
mark (mhpautos)
Jun 11, 2009 at 5:35 AM
