1989 Nissan Bluebird battery indicator stays on while ignit
1989 NISSAN BLUEBIRD
RIDGE
Electrical problem
1989 Nissan Bluebird 4 cyl Two Wheel Drive Manual
Note: when altenator plug is removed, the battery indicator goes OFF (and the Lamp check relay also goes off). The battery indicator stays even while ignition is OFF.
Nov 30, 2009 at 4:49 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I would be thinking that you have a faulty alternator and voltage is back feeding through a failed diode, i would check this out first.
Mark (mhpautos)
Nov 30, 2009 at 7:00 PM
