2006 Nissan Armada Brake Lights
2006 NISSAN ARMADA
51,000 MILES • V8 • 4WD • AUTOMATIC
SAMROHIT
I am not able the diagnose this problem. While the suv is running sometimes the hand brake light will turn on and if you apply the brakes then it sought off jams and makes noise. If you then stop the engine and start again, the light goes away and brake operates normal. This problem comes and goes away, bit I am not able to diagnose the problem. Fluid levels are good. Checked the rear brake and everything is functionally good.
Is this a problem of booster or some other hydraulic issue?
Mar 16, 2010 at 11:36 AM
TRAVJ
I have been driving the 06 Armada for 2 days on a trail test drive and this happened to me today. After researching online I ran across a recall on 06 brakes.
Brakes: SERVICE BRAKES, HYDRAULIC
Service Bulletin Number: 6016
NHTSA Number: 10019412
Model Years Affected: 2005, 2006
Date of Bulletin: 03/2006
Bulletin Summary: GROAN NOISE FROM FRONT BRAKES. NISSAN.
Not sure if this is the problem but could be. The dealer said he would have this fix but I'm not trusting them to fix it correctly. I will forward him this same recall tommorrow. Let me know if you have any more info.
Apr 23, 2010 at 11:16 PM
SAMROHIT
thank you. i am still having this problem, however shall contact the dealer and advise.
Apr 24, 2010 at 1:14 AM
